Jester
Full Member level 6
Please help me get a better understanding of common mode voltage. Assuming the op amp below has a specified common mode range that is limited to the range of the power supply rails (ground to 3.3V in this case).
AND the measurement circuit on the RHS has no intentional connection to earth or chassis ground.
The voltage being measured (V1-V2) is small, however it's sitting on a large common mode voltage.
Considering that the circuit on the RHS has no intentional connection to earth (just stray capacitance), can I ignore the fact that the common mode voltage is well outside the range of U1 for this measurement?
