maxplanck
Newbie level 6
No, as FvM has already told you it will saturate way below 15 amps.Thanks friend,
I have 15A rated current CMC. So, I can't this for 10A DC current?
In the common mode connection, 15 amps flows one way through the first winding, then back the other way through the second winding.
This causes the dc in each winding to totally cancel out to zero in the magnetic core.
What you are trying to do is feed dc current through both windings in the same direction.
The dc currents add together, not cancel each other out. So it will not work that way.
