kmdineshece
Member level 1
- Joined
- Dec 17, 2013
- Messages
- 36
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 384
how common collector has high input impedance than others?
is this circuit correct?...
Base-emitter--->Reverse
Collector-Base--->Forward Bias
For a common collector amplifier (emitter follower), the DC bias is exactly the same as a common emitter amplifier, its just the signal in/out is different.
Frank
Am I Correct Sir?
........When you are doing this, the load appears to be a much-higher value of resistance as the transistor multiplies the resistance of the load by a factor of about 100 times.
That's why the circuit is classified as having a HIGH INPUT IMPEDANCE.
Colin55, everything OK - however, WHY is the transistor doing this amazing multiplication by a factor of 100?
You shouldn´t keep secret the reason: Negative feedback.
It is a well-established knowledge that negative current-controlled voltage feedback reduces the gain and increases the input resistance - all with the same factor: (1+ magnitude of loop gain.)
Hi colin55here is no such thing as NEGATIVE FEEDBACK in this case and you should not be using the term.
Of course we all know what negative feedback is . but you must understand real concept of the transistor . have you ever though why we call it transistor ? because it transfer resistance . how ? one of the most usual ones is , from emitter to the base or vice versa . so it means something is reflecting from the out put into the input . so what you call this ? isn't this a feedback ??!!! of course it is !Negative feedback is when the output signal is re-directed back to the input to reduce the gain and reduce the distortion.
Hi colin55
Sorry but i'm completely disagree with your statement .
So you must use the word feedback too !
Best Luck
Goldsmith
You are completely wrong in your reasoning.
I have been teaching electronics for 40 years and written 25 books with sales of over 750,000 copies. My website has reached 22,000,000 visitors.
No-one has yet said I have been wrong.
To start with, negative feedback REDUCES the overall effect.
Show me one book where it states the emitter resistor provides NEGATIVE FEEDBACK.
You are getting confused with the common emitter stage where the emitter resistor provides EMITTER DEGENERATION.
Here in Iran there is an old saying which says when a tree has more fruits , it's head is nearby the ground ! you know what does it mean ? it mean when somebody has a lot of knowledge and a lot of things he/she won't try to say it to a lot of people . and i guarantee that , here on EDA there a lot of pretty famous and absolutely more experienced persons in compare with you . ( of course i'm not one of them ) .so don't suppose that you are just one of the kind , ok ? . don't try to fight the idea of negative feedback in this case because you have not saw this before . okay ?You are completely wrong in your reasoning.
Did you find this post helpful? Click: Yes
The emitter follower
The emitter follower or common-collector amplifier (Fig.4.4) is best considered as a series feedback amplifier in which the output is taken from the emitter rather than from the collector.
In simple terms, the output voltage is separated from the input voltage by the almost constant voltage drop across the forward biased base-emitter junction. As the input voltage varies, so does the forward biased base-emitter junction. As the input voltage varies, so does the output in almost exact sympathy except for the 0.7 V d.c. offset. The emitter is said to follow the base, hence the term emitter follower and the circuit is expected to have a voltage gain of unity (+1 since this no signal inversion between the base and emitter).
Analysis of the a.c. equivalent circuit is necessary to yield accurate expressions for voltage gain, input resistance and output resistance.
The procedure for determining the input resistance in the transistor rin(t) is identical to that for the series feedback amplifier and yields the same result, i.e.
Acc=Gm*Re/(1+gm*Re)
Reference:Transistor Circuit Techniques: Discrete and integrated, Chapter 4: Single-Stage BJT Amplifiers with Feedback, Page: 59-60
The text continues to derive the Av or Acc equation previously indicated by LvW:
I have several other texts in my library with a similar treatise of the common collector or emitter follower configurations which utilize the concept of feedback in their derivations.
BigDog
