[SOLVED] common cathode 7-segment display driver resistors on anodes or cathodes?
neazoi
Advanced Member level 6
Greece
www.microwave.gr
Hi, I have a common cathode 7-segment display and I am trying to decide where to put the resistors, on the anode (one for each segment) or at the cathode (only one resistor required)?
Obviously just one resistor on the cathode ismore economical but how about the display brightness, will it be affected depended on the number of segments lit?
Yes it will, more segments On, less LED light intensity.
E
Reactions: neazoi
    neazoi
You definitely should use resistor for each LED segment on the anode side, this way you'll have constant brightness. You may also want to have a look at constant current LED driver circuits. MAX7219 would be really good choice for your application.
Good luck.
Reactions: neazoi
    neazoi
