I think pretty much it is the correct approach. Since it is a sample and hold circuit and not really a continuous signal, you should be ok if just collecting samples at the end of the hold phase, which means you just need to have a strobe period of 1/2GHz. Also, leave some time in the beginning to let initial transients die out before you start collecting samples.
