IMSlo
Newbie level 6
is lo or hi better porta 16f88
Can someone tell me why the attached code won't run on a 16f88 PIC. This is a simple elapsed time timer running on a timer0 interrupt and displaying the time on a 2 X 16 LCD. I downloaded the code from several places and put it together. With the minor necessary changes the code will run for days on a 16f627a. On the 88 it will run a few seconds, zero up run a few seconds, zero up and maybe even run a few minutes and zero up. It will eventually quit some times with the display showing numbers and again with the display blank. I'm at my wit's end. Please ignore the comments because they may or may not be right. Any help would be appreciated.
; ZERO-ERROR ONE SECOND TIMER
; (Roman Black 2001, public domain, use it as you like)
; processor defined ;
LIST p=16F88 ;tell assembler what chip we are using
include "P16F88.inc" ;include the defaults for the chip
ERRORLEVEL 0, -302 ;suppress bank selection messages
; MPLAB stuff here
LIST b=5, n=97, t=ON, st=OFF
; absolute listing tabs=5, lines=97, trim long lines=ON, symbol table=OFF
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_IO
;Program Configuration Register 2
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
LCD_PORT Equ PORTB
LCD_TRIS Equ TRISB
LCD_RS Equ 0x04 ;LCD handshake lines
LCD_RW Equ 0x06
LCD_E Equ 0x07
; Variables here
CBLOCK 0x20
sec
sec10
min
min10
hr
hr10
bres_hi ; hi byte of our 24bit variable
bres_mid ; mid byte
bres_lo ; lo byte
; (we only need 3 bytes for this system)
status_temp ; used for interrupt servicing
w_temp ; used for interrupt servicing
templcd ;temp store for 4 bit mode
templcd2
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
oldtime
ENDC
; Code here
org 0x000 ; Set program memory base at reset vector 0x000
reset
goto setup ; set up ints and port stuff
org 0x004 ; Interrupt vector, int handler code comes next.
; INTERRUPT HANDLER (runs this code each timer0 interrupt)
int_handler
; first we preserve w and status register
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; Note! we get here every 256 instructions, we
; can now do our special one second timing system.
; This consists of three main steps;
; * subtract 256 counts from our 24bit variable
; * test if we reached the setpoint
; * if so, add 1,000,000 counts to 24bit variable and generate event.
; * optimised 24 bit subtract here
; This is done with the minimum instructions.
; We subtract 256 from the 24bit variable
; by just decrementing the mid byte.
tstf bres_mid ; first test for mid==0
skpnz ; nz = no underflow needed
decf bres_hi,f ; z, so is underflow, so dec the msb
decfsz bres_mid,f ; dec the mid byte (subtract 256)
; now the full 24bit optimised subtract is done!
; this is about 4 times faster than a "proper"
; 24bit subtract.
goto int_exit ; nz, so definitely not one second yet.
; in most cases the entire int takes
; only 16 instructions.
; * test if we have reached one second.
; only gets here when mid==0, it MAY be one second.
; only gets to here 1 in every 256 times.
; (this is our best optimised test)
; it gets here when bres_mid ==0.
tstf bres_hi ; test hi for zero too
skpz ; z = both hi and mid are zero, is one second!
goto int_exit ; nz, so not one second yet.
; Only gets to here if we have reached one second.
; now we can generate our one second event, like add
; one second to our clock or whatever.
; (in this example we toggle a led)
; The other thing we need to do is add 1,000,000 counts
; to our 24bit variable and start all over again.
; Add the 1,000,000 counts first.
; One second = 1,000,000 = 0F 42 40 (in hex)
; As we know hi==0 and mid==0 this makes it very fast.
; This is an optimised 24bit add, because we can
; just load the top two bytes and only need to do
; a real add on the bottom byte. This is much quicker
; than a "proper" 24bit add.
movlw 0x0F ; get msb value
movwf bres_hi ; load in msb
movlw 0x42 ; get mid value
movwf bres_mid ; load in mid
movlw 0x40 ; lsb value to add
addwf bres_lo,f ; add it to the remainder already in lsb
skpnc ; nc = no overflow, so mid is still ok
incf bres_mid,f ; c, so lsb overflowed, so inc mid
; this is optimised and relies on mid being known
; and that mid won't overflow from one inc.
; that's it! Our optimised 24bit add is done,
; this is roughly twice as quick as a "proper"
; 24bit add.
; now we do the "event" that we do every one second.
; Note! for this example we toggle a led, which
; will give a flashing led which is on for a second
; and off for a second.
; Add your own code here for your one second event.
; Note! My led is on porta,3
; your led may be on a different pin.
; movlw b'00001000' ; mask for bit 3
; xorwf PORTB,f ; toggle PORTA,bit3 (toggle the led)
movlw sec ; point at sec register
movwf FSR
newdigit: incf INDF, f ; current digit up one
movlw sec ; get difference between sec and FSR
subwf FSR, W
call sethi ; use to get high limit + 1
subwf INDF, W ; reached that number yet?
btfss STATUS, Z ; skip over if yes
goto int_exit ; else exit isr
clrf INDF ; set current digit to 0
incf FSR, f ; point at next digit
goto newdigit ; no, increment the next digit
; now our one second event is all done, we can exit the
; interrupt handler.
; finally we restore w and status registers.
; also clears TMRO int flag now we are finished.
int_exit
BCF INTCON,2 ; reset the tmr0 interrupt flag
bcf STATUS,Z
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
; High limit + 1 of digits at position W ;
sethi:
addwf PCL, f
dt H'A',H'6',H'A',H'6',H'A',H'A'
; SETUP (runs this only once at startup)
setup ; goto label
movlw B'01100000' ; 4Mhz = B'01100000'
banksel OSCCON
movwf OSCCON
banksel 0
;Wait until osc stabilizes
lp:
btfss OSCCON, 2
goto lp
; Note! 16F84 version.
; Note! here we set up peripherals and port directions.
; this will need to be changed for different PICs.
; OPTION setup
movlw b'00001000' ;
; -------x ;
; Note! We set the prescaler to the wdt, so timer0
; has NO prescaler and will overflow every 256
; instructions and make an interrupt.
banksel OPTION_REG ; go proper reg bank
movwf OPTION_REG ; load data into OPTION_REG
banksel 0 ; back to normal bank 0
; PORTB pins direction setup
; 1=input, 0=output
clrf PORTB ;
movlw b'00000000' ; all 8 portb are outputs
banksel TRISB ; go proper reg bank
movwf TRISB ; send mask to portb
banksel 0 ; back to normal reg bank
; PORTA pins direction setup
; 1=input, 0=output
clrf PORTA ;
movlw b'00000000' ; all 5 porta are outputs,
; (with 16F84 porta only has lower 5 bits)
banksel TRISA ; go proper reg bank
movwf TRISA ; send mask to porta
; INTCON setup
; for this code example, we enable the timer0
; overflow interrupt.
; enable interrupts last
; interrupt setup
movlw b'11100000' ; GIE=on TOIE=on (timer0 overflow int)
; bsf INTCON,7
; bsf INTCON,6
; bsf INTCON,5
banksel INTCON
movwf INTCON
banksel 0
clrf sec
clrf sec10
clrf min
clrf min10
clrf hr
clrf hr10
; Note! Now the hardware is set up we need to load the
; first count for one second into our 24bit bres variable.
; Note! This example uses 4 MHz clock, which is
; 1,000,000 counts per second.
; We require a 1 second period, so we must load
; 1,000,000 counts each time.
; 1,000,000 = 0F 42 40 (in hex)
; We also need to add 256 counts for the first time,
; so we just add 1 to the mid byte.
; Check mid overflow if needed.
; here we load the 24bit variable.
movwf bres_hi ; put in hi
movlw 0x42 +1 ; get mid value (note we added 1 to it)
movwf bres_mid ; put in mid
movlw 0x40 ; get lsb value
movwf bres_lo ; put in mid
;call LCD_Init
; now setup is complete, we can start execution.
goto main ; start main program
;Initialise LCD
LCD_Init call Delay100 ;wait for LCD to settle
movlw 0x20 ;Set 4 bit mode
call LCD_Cmd
movlw 0x28 ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd ;Set cursor off
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd movwf templcd
swapf templcd, w ;send upper nibble
andlw 0x0f ;clear upper 4 bits of W
movwf LCD_PORT
bcf LCD_PORT, LCD_RS ;RS line to 1
call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_CharD addlw 0x30 ;add 0x30 to convert to ASCII
LCD_Char movwf templcd
movwf LCD_PORT
bsf LCD_PORT, LCD_RS ;RS line to 1
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_Line1 movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2 movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_CurOff movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
;LCD_HEX movwf tmp1
; swapf tmp1, w
; andlw 0x0f
; call HEX_Table
; call LCD_Char
; movf tmp1, w
; andlw 0x0f
; call HEX_Table
; call LCD_Char
; retlw 0x00
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Pulse_e bsf LCD_PORT, LCD_E
nop
bcf LCD_PORT, LCD_E
retlw 0x00
;end of LCD routines
DispTime
MOVLW 0x04
CALL LCD_Line1W
movf hr10,w
CALL LCD_CharD
movf hr,w
CALL LCD_CharD
MOVLW ":"
CALL LCD_Char
movf min10,w
CALL LCD_CharD
movf min,w
CALL LCD_CharD
MOVLW ":"
CALL LCD_Char
movf sec10,10
CALL LCD_CharD
movf sec,w
CALL LCD_CharD
RETURN
; MAIN (main program loop)
main ; goto label
call LCD_Init
; Note! This example uses the timer0 overflow interrupt.
; This will interrupt our main program every 256 instructions
; and do the one second timer system.
main_loop ;
movf oldtime, W ; is oldtime the same as sec?
subwf sec, W
btfsc STATUS, Z ; if not, skip over next instruction
goto main_loop ; else continue checking
call DispTime ; sec has changed, display the time
movf sec, W ; make sec and oldsec the same
movwf oldtime
; or calls to the main program pieces.
; The interrupt does all the one second timer stuff.
; stuff
; stuff
; stuff
; stuff
goto main_loop ; keep running the main code.
end ; no code after this point.
; MPLAB stuff here
LCD_PORT Equ PORTB
LCD_TRIS Equ TRISB
LCD_RW Equ 0x06
LCD_E Equ 0x07
; Variables here
CBLOCK 0x20
sec
sec10
min
min10
hr
hr10
bres_mid ; mid byte
bres_lo ; lo byte
templcd2
oldtime
ENDC
; Code here
reset
int_handler
; 24bit subtract.
; 24bit add.
movwf FSR
subwf FSR, W
int_exit
bcf STATUS,Z
swapf w_temp,f
sethi:
addwf PCL, f
setup ; goto label
banksel OSCCON
movwf OSCCON
banksel 0
lp:
btfss OSCCON, 2
goto lp
; OPTION setup
movlw b'00001000' ;
; -------x ;
; 1=input, 0=output
clrf PORTB ;
; 1=input, 0=output
clrf PORTA ;
; INTCON setup
; interrupt setup
; bsf INTCON,7
; bsf INTCON,6
; bsf INTCON,5
banksel INTCON
movwf INTCON
banksel 0
clrf sec
clrf sec10
clrf min
clrf min10
clrf hr
clrf hr10
;call LCD_Init
;Initialise LCD
call LCD_Cmd
call LCD_Cmd
call LCD_Cmd
retlw 0x00
movwf LCD_PORT
movwf LCD_PORT
call Delay5
retlw 0x00
movwf LCD_PORT
movwf LCD_PORT
call Delay5
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
call LCD_Cmd
retlw 0x00
;LCD_HEX movwf tmp1
; swapf tmp1, w
; andlw 0x0f
; call HEX_Table
; call LCD_Char
; movf tmp1, w
; andlw 0x0f
; call HEX_Table
; call LCD_Char
; retlw 0x00
goto d0
goto d0
goto d0
goto d0
d0 movwf count1
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
nop
bcf LCD_PORT, LCD_E
retlw 0x00
DispTime
MOVLW 0x04
CALL LCD_Line1W
movf hr10,w
CALL LCD_CharD
movf hr,w
CALL LCD_CharD
MOVLW ":"
CALL LCD_Char
movf min10,w
CALL LCD_CharD
movf min,w
CALL LCD_CharD
MOVLW ":"
CALL LCD_Char
movf sec10,10
CALL LCD_CharD
movf sec,w
CALL LCD_CharD
RETURN
main ; goto label
call LCD_Init
main_loop ;
subwf sec, W
movwf oldtime
; stuff
; stuff
; stuff
; stuff
