[SOLVED] Code not running when large array of initialized global variables are used
freemanantony
Member level 4
Member level 4
Chennai, India
haai every body ,
i have written a c code with a large array initialized global variable, when i am using this large array the code is not even hitting the first line of the code( i have inserted a break point and checked), but when i am commenting that global variable code is running. I am not sure what the problem is. The microcontroller i am using is C8051F340 (Silabs), and Silabs ide and debugger with keil compiler. Can anyone help me on this?
Why don't you debug right from the start, including the RTL startup code?
You say, there are no compilation errors or warnings and all compiler listings and memory maps look fine?
yes FvM, the problem is solved, the problem was caused by the overflowing of watchdog timer, so i disabled the watchdog timer in the start up code itself and now the code is working fine
