Code for encoder in VHDL
xilinx1001
Member level 3
Member level 3
I need to write a VHDL module with the entity and the behavioral description of the combinational network that encodes the seven segment of the display
The encoder must be capable of encoding a hexadecimal digit from four binary bits.
Can anyone suggest me how to start with this
Regards
Vivek Alaparthi
heres the first couple of lines for you:
library ieee;
use ieee.std_logic_1164.all;
Ok, cynical posting asside - there are many examples of this on this forum. You're just making a 4-7 encode. you need to work out which LEDs need to be turned on for each hex digit.
