gauravkothari23
Advanced Member level 2
- Joined
- Mar 21, 2015
- Messages
- 644
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,298
- Activity points
- 6,948
Hi friends....
plz help me
as i am new for programming...
i wrote the code in c but am getting an error in keil as
my code is......
plz help me
Project1.c(19): warning C206: 'Lcd8_Cmd': missing function-prototype
Project1.c(19): error C267: 'Lcd8_Cmd': requires ANSI-style prototype...
my code is......
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 #include<reg51.h> #include<delay.h> #include<lcd.h> #include<keypad.h> void lcd_cmd(unsigned char ); void lcddata(unsigned char ); void lcdready(); void MSDelay(unsigned int ); sbit LEDg=P2^4; sbit LEDr=P2^3; //// FUNCTIONS FOR LOCK image on LCD//// void lock() { Lcd8_Cmd(72); Lcd8_Write_Char(0); Lcd8_Write_Char(14); Lcd8_Write_Char(10); Lcd8_Write_Char(10); Lcd8_Write_Char(31); Lcd8_Write_Char(27); Lcd8_Write_Char(31); Lcd8_Cmd(0xcf); Lcd8_Write_Char(1); } void open() { Lcd8_Cmd(72); Lcd8_Write_Char(14); Lcd8_Write_Char(10); Lcd8_Write_Char(2); Lcd8_Write_Char(2); Lcd8_Write_Char(31); Lcd8_Write_Char(27); Lcd8_Write_Char(31); Lcd8_Cmd(0xcf); Lcd8_Write_Char(1); } //// FUNCTION INPUTTING VALES FROM USERS AND STORING THEM TO AN ARRAY//// void input(char arr[]) { unsigned char i=0,k=0,N[16]; Lcd8_Cmd(0xc0); while(k!='#') { k=Read_Keypad(); if(k && k!='#') { N[i++]=k; Lcd8_Write_Char('*'); } } strcpy(arr,N); arr[i]='\0'; } void main() { unsigned char P[16]={"000"}; ///default password while(1) { unsigned char p[16],s[16],j; LEDg=0;LEDr=1; Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("ENTER PASSWORD"); input(p); if(strcmp(p,P)==0) { Lcd8_Init(); open(); Lcd8_Cmd(0x80); Lcd8_Write_String("ACCESS GRANTED"); LEDr=0;LEDg=1; while(Read_Keypad()!='#') {} } else if(strcmp(p,"*")==0) { Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("CURRENT PASSWORD"); input(p); if(strcmp(p,P)==0) { Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("NEW PASSWORD"); input(s); Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("CONFIRM PASSWORD"); input(p); if(strcmp(p,s)==0) { j=strlen(s); strcpy(P,s); P[++j]='\0'; Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("CHANGE"); Lcd8_Cmd(0xc0); Lcd8_Write_String("SUCCESSFULL"); while(Read_Keypad()!='#') {} } else { Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("CHANGE"); Lcd8_Cmd(0xc0); Lcd8_Write_String("UNSUCCESSFULL"); while(Read_Keypad()!='#') {} } } else { Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("WRONG PASSWORD"); delay_msec(2000); } } else { Lcd8_Init(); lock(); Lcd8_Cmd(0x80); Lcd8_Write_String("ACCESS DENIED"); LEDr=0;delay_msec(250); LEDr=1;delay_msec(250); LEDr=0;delay_msec(250); LEDr=1;delay_msec(250); LEDr=0;delay_msec(250); LEDr=1;delay_msec(250); } } } ---------------------------------------------------------------------------------- CODE (delay.h) ---------------------------------------------------------------------------------- void delay_msec(int time) {int i=0; while(i<time) {TMOD=0x10; TH1=0xfc; TL1=0x65; TR1=1; while(TF1==0); TR1=0; TF1=0; i++; } } -------------------------------------------------------------------------------------- CODE (lcd.h) -------------------------------------------------------------------------------------- #include<string.h> //LCD Module Connections sbit RS=P2^0; sbit RW=P2^1; sbit E=P2^2; //End LCD Module Connections char *string; //LCD 8 Bit Interfacing Functions void Lcd8_Cmd(unsigned char value) { P3=value; RS=0; RW=0; E=1; delay_msec(1); E=0; } void Lcd8_Init() { Lcd8_Cmd(0x38); //function set Lcd8_Cmd(0x0C); //display on,cursor off,blink off Lcd8_Cmd(0x01); //clear display Lcd8_Cmd(0x06); //entry mode, set increment } void Lcd8_Write_Char(unsigned char value) { P3=value; RS=1; RW=0; E=1; delay_msec(1); E=0; } void Lcd8_Write_String(char *a) { int i; string=a; for(i=0;a[i]!='\0';i++) Lcd8_Write_Char(a[i]); } void Lcd8_Shift_Right() { int j; for(j=0;j<strlen(string);j++) {Lcd8_Cmd(0x1C);delay_msec(100);} } void Lcd8_Shift_Left() { int k; for(k=0;k<strlen(string);k++) {Lcd8_Cmd(0x18);delay_msec(100);} } ------------------------------------------------------------------------------ CODE (keypad.h) ------------------------------------------------------------------------------ sbit R1 = P1^0; sbit R2 = P1^1; sbit R3 = P1^2; sbit R4 = P1^3; sbit C1 = P1^4; sbit C2 = P1^5; sbit C3 = P1^6; sbit C4 = P1^7; //End Keypad Connections char Read_Keypad() { C1=C2=C3=C4=1; R1=0; R2=1; R3=1; R4=1; if(C1==0){while(C1==0);return '1';} if(C2==0){while(C2==0);return '2';} if(C3==0){while(C3==0);return '3';} if(C4==0){while(C4==0);return 'A';} R1=1; R2=0; R3=1; R4=1; if(C1==0){while(C1==0);return '4';} if(C2==0){while(C2==0);return '5';} if(C3==0){while(C3==0);return '6';} if(C4==0){while(C4==0);return 'B';} R1=1; R2=1; R3=0; R4=1; if(C1==0){while(C1==0);return '7';} if(C2==0){while(C2==0);return '8';} if(C3==0){while(C3==0);return '9';} if(C4==0){while(C4==0);return 'C';} R1=1; R2=1; R3=1; R4=0; if(C1==0){while(C1==0);return '*';} if(C2==0){while(C2==0);return '0';} if(C3==0){while(C3==0);return '#';} if(C4==0){while(C4==0);return 'D';} return 0; }
