noor_awad
Junior Member level 2
Hello
I am working on a project of simulating a microstrip antenna to verify the results obtained in a published paper (attached)
I am new to HFSS and I can't excite the antenna to get the published results
I am working on HFSS v11 and have attached the design file I created (there may be errors (not in geometry, i think in feeding)
i tried to calculate the inner and outer diameter of the coaxial from the site below
but still the results bad
i used air filling inside the coaxial, and i tried teflon aslo but nothing change
i took the air box to be lambda /4 from the all direction
center frequency is 0.9GHz
realy i need a help
please
realy i need a help
please
