emresel
Full Member level 5
Hello;
I will use around 1~1.5m coax cable upto 6Ghz. Feed connector is SMA type.
I found below can be used with SMA.
RG142, RG58, RG316, RG316 DS (Double Shileded)
Can you grade them from good to bad?
As i understand rg142 is better. But i cannot decide if rg58 or rg316 is better.
Are those bad to use such freq (~6ghz) for short distances?
Any other advises welcome.
