kelvin_sg
I have a 500K gate, 40MHz design. When I first implemented that
for xc2v6000, P&R succeeded with 2ns margin. Now I decided to
inserted a parallel - serial converter, by using DCM to raise the clock
to 80MHz, synchronized with original 40MHz clock. The logic in P-S
is quite simple, however, after I ran P&R, the timing violation for 40MHz
occur and max path roared to 45ns, but timing for 80MHz is 10.5ns.
I thought it was caused by the P-S and the output path, so I added a ring
of 8 registers to the serial output in order to break down the output path
and minimize its effect on the 40MHz design (whose timing was very tight).
Now I achieved a 10.2ns on 80MHz clock and 37ns on 40MHz clock. Far
from my goal. Device utilization was abundant at this time.
Am I doing the right thing? What trick can you advise?
Thank you
Thank you
