clock level translation
explorick
I want to level translate a 3.3V CMOS, 15MHz clock signal to 1.8V CMOS clock 15MHz clock signal. Can i use 74LVC1T45GW( **broken link removed** ) for this.The datasheet only talks about data rate and will there be any skew or jitter problems if this device is used. If this device cannot be used do you have any recommendation.
if the source is crystal/oscillator, it is better to change the part which is based on 1.8V CMOS. if you are deriving the clock from any synthesizer circuitry, then you can consider the above part. i suggest to use ADG3241 since it supports high bandwidth. the above part is also good choice. all the best.
I am having a synthesizer circuit whose output is 3.3V CMOS. So i need to convert to 1.8V CMOS. Will there be no jitter problems considering the propagation delay variation with the devices chosen?
