1. You can use pulse generators to generate a clock on every rising/falling edge to get 2x clock.
2. You can combine lower frequency clocks that has phase offsets to generate faster clocks, if phase offset clocks are available.
3. You can use DLLs to generate the phase offset clocks and combine to generate faster clocks.
4. You can use PLL to generate faster clocks.
