Clearing the mailbox in system verilog
rkini
Is it possible to clear the mailbox contents?? Say if I want to flush out the contents of the mailbox at a certain point in my code, is there a way to do that???
You have to do this in a loop with try_get
while (my_mailbox.try_get(tx)) ; //this does a flush of the mailbox
The only problem with this is if you have pending blocked get()s on the same fifo. this code might not work properly ( a race) See http://www.eda.org/svdb/view.php?id=1738
Reactions: rkini
    rkini
Will this approach also work if I havent bounded my mailbox?? I mean the try_get gets values only for the number of times of the contents and not the size of the mailbox, am I correct?
I have an environment class where i define a mailbox and construct its object as follows:
class environment;
mailbox driver2sb;
function void build()
driver2sb = new();// driver to scoreboard mailbox
endclass
In the scoreboard class i try to do :
class scoreboard;
mailbox driver2sb;
task start();
while(driver2sb.try_get());
begin
$display("Clearing driver mailbox");
end
endclass
However I get the following error message:
errors: 0, warnings: 0
ncvlog: *E,FAABPB (scoreboard.sv,52|22): task or function call does not specify all required formal arguments [10.2.2][10.3(IEEE)].
while(out2sb.try_get());
I dont know what I am doing wrong!
