Class in system verilog
sunidrak
Full Member level 1
Full Member level 1
Bengaluru, India
Can anybody plz explain the difference and meaning of the two Code Snippet highlighted...
code -1
class base;
task print();
endtask
endclass
class derived extends base;
task print();
endtask
endclass
module main();
base b; //Instance
derived d; //Instance
initial
begin
b=new();
d=b;
d.print();
end
endmodule
code-2
class base;
task print();
endtask
endclass
task print();
endtask
endclass
module main();
base b; //Instance
initial
begin
b=new();
d=new();
d.print();
end
endmodule
plz explain the meaning of declaration in this manner
Regards
Sunil.
You need to Understand the difference between virtual and non-virtual methods in SystemVerlog. Search for examples of that.
in code1 print() task of base class will run or execute ..............in code2 print() task of class derived will execute.......you can refer to www.testbench.in and refer to inheritance section of oops
