Class-E oscillator claims near 100% measured efficiency
neazoi
Advanced Member level 6
Greece
I have build and tested the attached circuit (image), from the PDF file which claims to be a near 100% efficient class-e crystal oscillator. However the efficiency I measure seems very bad.
First of all, shall I measure it on 50R or on 1Meg?
I am confused about my measurements on the scope, with VPP and with the its FFT, I may be doing something wrong.
  • J2011F.pdf
1 Meg but I'm not sure what you are trying to measure. In this context the load is power delivered through the 2.7uH inductor, it isn't intended to drive further circuitry. The 2.7uH coil is essentially the primary of a transformer that couples magnetically to a medical implant.
Brian.
Reactions: neazoi
    neazoi
They don't show waveforms for the circuit with the ~100% supposed efficiency. But they do show waveforms for a higher power version of the circuit, and they look very poor (and they don't state the efficiency of that circuit, it's likely <80%). Overall everything here is pretty questionable.
Reactions: neazoi
    neazoi
I really wonder what's the purpose of this thread. You can surely improve efficiency by forcing the oscillator operation point towards "class-E". Making a near "100 %" single transistor oscillator seems pretty useless to me, even if it would be possible. You get better control of frequency, output power and maximum efficiency in a multi stage design in any case.
An output stage has to be adapted for the actual load impedance, the question suggests that you have presently no clue what you want to achieve with the circuit.
Reactions: neazoi
    neazoi
Neither one. If you want to follow the paper.
Reading a few lines you can realize that they have measured the efficiency of the "oscillator" without any load. That is why very high efficiency is measured, unfortunately is pointless, as FvM mentioned.
Besides, the paper is overall doubtful.
PAGE 10, referring to fig 8:
The power used by this circuit is 77mW (18.9dBm), which is determined
by multiplying the supply voltage with the r.m.s. value of the total current.
I hope it is a typo.
Reactions: neazoi
    neazoi
I saw on the net this "keychain transmitter" and I thought a better design could be made in a keychain emergency shortwave transmitter. First thought of course was to include a battery in it, but the overall thing has to be small, so efficiency does matter if one wants to achieve max range.
So I started to look for class-E oscillators, because the space and available DC power is very limited. I may be in the wrong path, so any thoughts are appreciated.
Brian.
No medical implant in my case, just an emergency transmitter very small sized and as much powerful as possible. This calls for a class-E circuit I guess. I am looking for low voltage designs too, as single cell batteries would be convenient with it I guess.
If I could find a 1.5v crystal oscillator that can provide quite a few 10s or 100s mW of output power, this would be all that would be needed actually.
I wouldn't worry about class-E or efficiency in that case, concentrate on output purity and being able to modulate it sensibly. A carrier alone is highly unlikely to be of much use unless it can be picked out from all the other carriers across the spectrum.
Also beware of "100s mW" from a crystal oscillator. A low power crystal oscillator and conventional PA to boost it's output to 100mW+ would be more efficient, particularly when you need to match it to some kind of antenna.
Brian.
Not sure what sort of modulation is used for "emergency shortwave" transmission. Class E would be fine for something like OOK, FSK, PSK, etc. Otherwise you'll want to stick with a linear output stage like class A or B.
He uses CW (OOK).
I have found a very interesting circuit, which needs no battery at all!
https://www.youtube.com/watch?v=guIRbb8ETGg
Although this would not fit into a key chain...
Now I am starting to think of a tony pneumatic power generator, maybe a tiny fanned motor generator would be easier to produce power. Something like blowing inside a straw, with a tiny fan-magnet attached at the air output. I am looking for such designs on the net but I have no success.
Any ideas are welcome.
