Why would you want to waste power? Normally you just have to provide current to the load; usually there's no need to sink current. But may be you've got a different application?
If the LDO delivers a pulse signal frm 0mA to 300mA. The load transient has a drop and then an overshoot.
Without a push-pull stage, the overshoot will be pretty high.
But I am wondering is my consideration of the overshoot in general important for LDOs?
And how much power loss is expected for adding a class AB stage?
If you want to get pretty load transient, you need to improve Error AMP and driver blocks for Power MOS. I don't think push-pull stage is good solution for that.
Class AB is one of solution. Another solution is adding a comparator for overshoot detecting.
Of cos, overshoot suppression is important for LDO design.
Quescient current could be increased with class AB. However, it depends on your design.
