mtwieg
Advanced Member level 6
- Joined
- Jan 20, 2011
- Messages
- 3,907
- Helped
- 1,311
- Reputation
- 2,628
- Reaction score
- 1,435
- Trophy points
- 1,393
- Activity points
- 30,018
Recently I've been reading up on LDMOS ruggedness and came across documentation claiming that they can deliver their full rated output power into high VSWR (like 10:1 and over). Is this just referring to the incident power on the load, or the net power into the load (that is, the difference between incident and reflected power)? It can't possibly be the latter case, right? As I understand it, if your VSWR is 10:1 then you have to dissipate ten times the power to deliver the same net power to the load than you would if VSWR was 1:1.
