Binome
Full Member level 3
- Joined
- Nov 16, 2009
- Messages
- 152
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Lyon, France
- Activity points
- 2,405
I want to create a circular FIFO to reuse the free memory. Here is my code:
I tried to write words without reading and I've got problems: full and err signals are being 1 only during one cycle and err is one cycle too late.
Do you know a solution?
Thanks.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ring_fifo is
generic(
fifo_length : integer:=8;
data_width : integer:=4);
port(
clk : in std_logic;
rst : in std_logic;
ren : in std_logic;
wen : in std_logic;
dataout : out std_logic_vector(data_width-1 downto 0);
datain : in std_logic_vector(data_width-1 downto 0);
empty : out std_logic;
err : out std_logic;
full : out std_logic);
end ring_fifo;
architecture arc of ring_fifo is
type memory_type is array (0 to fifo_length-1) of std_logic_vector(data_width-1 downto 0);
signal memory : memory_type := (others => (others => '0'));
signal readptr,writeptr : integer range 0 to fifo_length-1 := 1;
signal rcycle,wcycle : std_logic := '0';
signal full0 : std_logic := '0';
signal empty0 : std_logic := '1';
begin
full <= full0;
empty <= empty0;
fifo0: process(clk,rst)
begin
if rst='1' then
readptr <= 0;
writeptr <= 0;
rcycle <= '0';
wcycle <= '0';
full0 <= '0';
empty0 <= '1';
err <= '0';
elsif rising_edge(clk) then
if (wen='1' and full0='0') then
memory(writeptr) <= datain ;
if (writeptr=fifo_length-1) then
wcycle <= not wcycle;
writeptr <= 0;
else
writeptr <= writeptr+1;
end if;
end if;
if (ren='1' and empty0='0') then
dataout <= memory(readptr);
if (readptr=fifo_length-1) then
rcycle <= not rcycle;
readptr <= 0;
else
readptr <= readptr+1;
end if;
end if ;
if ((writeptr + 1 = readptr)) or ((writeptr=fifo_length-1) and (readptr=0)) then
full0 <= '1';
else
full0 <= '0';
end if;
if (readptr = writeptr) then
empty0 <= '1';
else
empty0 <= '0';
end if;
if (empty0='1' and ren='1') or (full0='1' and wen='1') then
err <= '1';
else
err <= '0';
end if;
end if;
end process;
end arc;
Thanks.
