circular buffering-problem
Ma3ix
Member level 2
Hi, I need help for my code. Im trying to do filtering (running average from circular buffer) from adc reading.
I wrote this code and tested it from bascom 8051 compiler and it works fine :
**circular buffer**
Dim array(3) As Byte
Dim P As Byte
Dim sum As Byte
Dim X As Byte
Dim counter As Byte
Dim average As Single
counter = 0
P = 0
sum = 0
Do
sum = sum - array(p)
Input "Input number:" , X
array(p) = X
sum = Sum + X
counter=counter + x
P = P + 1
P = P Mod 3
   If counter = 3 Then
      	average = Sum / 3
	counter = 2
   End If
Loop
If I enter 5 numbers , for example array= (x1=1, x2=3; x3=5; x4=7; x5=8)
i will get 3 averages:
average_1= x1 + x2 + x3
average_2= x2 + x3 + x4
average_3= x3 + x4 + x5
which is fine cause I want to replace the oldest input with newest.
When I put this code in my project(thermometer) it does not work!Only first average is fine on display, I guess that second line of this code "sum=sum-array(p)"
does not work with project.:/
Project works fine without circular buffering.
The logic is same
Do
- reading from senzor
- circular buffering (X is reading from ADC)
- do calculation for temperature
- send data to displays
loop
im coding in Bascom 8051 :(
FvM
Super Moderator
Staff member
Bochum, Germany
Means it's compiled without errors? O.K. but does it mean the code is correct?
Suggest to trace code operation with pencil and paper method, just writing down the results for every loop iteration. You surely see why it's not working as expected.
Ma3ix
Member level 2
I tested this part of code in Bascom simulator and it works (giving me correct results for running average)..
In Proteus simulation and in reality it gives me totally incorrect results:roll:
It seems to me that mcu does not remember elements of array after first average?:idea:
FvM
Super Moderator
Staff member
Bochum, Germany
Looks definitely wrong
counter=counter + x
