May 3, 2012 #1 H hannover90 Member level 4 Joined Dec 8, 2009 Messages 70 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Germany Activity points 1,784 Hello, I want to design a circuit, which its output voltage is smaller than input voltage: Uout = 0.6* Uin With an amplifier (A>=1) I can have a biger output voltage, but in this situation in which field of analog circuit shuld I research and try it? thanks and best regards Sarah
May 3, 2012 #2 E emontllo Full Member level 4 Joined May 9, 2011 Messages 194 Helped 62 Reputation 124 Reaction score 59 Trophy points 1,308 Activity points 2,694 You can use a simple resistor voltage divider. If you need low output impedance, use an opamp based voltage follower (i.e. gain A = 1 amplifier) after the divider.
