Christy414
Newbie
I am new and am don this as a hobby. I am trying to make two motion sensors turn on a fan. One on each side. I don't want to use PIR because the objects might not give off heat. So any suggestions as to which motion detector to use. I am also using an arduiono. And should I use a relay switch? Attached is a diagram rough draft. Thank you for your time.
