keremcant
Member level 5
I want to use a part in my simulation. The part is ADA4817-1. The Analog devices provide a file that is found in ADA4817-1 | Low Noise, 1 GHz FastFET Op Amps | FET Input Amplifiers | High Speed Op Amps (> 50 MHz) | Analog Devices under "spice models". However the file has an extension ".cir" and I don't know how to use it. I ama trying to simulate the circuit in orcad capture.
Any help will be appreciated.
