iceblu3710
Member level 3
- Joined
- Aug 10, 2009
- Messages
- 61
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,955
I am making a DC injection brake for a saw to add some safety to the unit and require a relay to make the system automatic. Here is a breakdown on how I need it to work:
120V 10A input
Start/Stop maintained switch
Press start button to start motor, when you press stop there will be a 1s delay and then DC will be put into the motor for 8s, then the motor will be isolated from the source until started again.
Essentially I have a rectifier and power resister I am inserting in series with the motor which is turning the 120VAC into DC.
I can not figure out what combination of things I would need as a delay-OFF would give me the 1s dead band and that could turn on a delay-ON for 8s but that would require two timers. I am hoping it can be done with just one. I am also open to using the start/stop button as a simple input and having the timer constantly powered. (I would use an e-stop button on the line voltage for emergencies)
120V 10A input
