per_lube
- Joined
- Sep 29, 2010
- Messages
- 107
- Helped
- 17
- Reputation
- 34
- Reaction score
- 17
- Trophy points
- 1,298
- Activity points
- 2,120
I'm working on a cheap receiver development for a point to point communication link working @11 GHz.
I'm using schottky diode detector as the receiver and can detect signals which are @ -35 dBm only with diode detector.
In order to improve the sensitivity, I'm planning to have LNA before the diode detector.
I found this one SKYWORKS SKY65013-92LF Cascadable Amplifier LF–12 GHz(https://www.skyworksinc.com/uploads/documents/200359B.pdf) which is very cheap (< $2) and easy to use (I/O 50 ohm matched).
However, Noise figure is 5.8 dB. Will this create problems if I use this one to amplify the received signals?
Could anyone explain me what might be the problems could occur with this amplifier?
cheers,
per_lube
cheers,
per_lube
