Hest
Junior Member level 1
Hello
I have a problem with my PCB manufacturer, because they can't see my drills. I'm using a CAM found on their site http://iteadstudio.com/store/images/produce/PCB/PCB prototype/ITeadstudio_CAM.rar so I thought that would be it.
Also, when I only look at the drill layer, I can see the drills (image).
How can I check if the drills are in the final files or not?
These are the files I get after the job is done.
When making the gerber file for drill (the .TXT?) only drills and holes are chosen in the right list, do I also need the dimension to be selected there and could that be the problem?
Hope you can guide me in the right direction.
