bobdxcool
Member level 5
I have a 12V, 200AH AGM battery. The maximum charging current recommended by the manufacturer is 50 amps. Now, I need to connect two AGM 12v batteries in series to connect to the input of my 24 volt inverter with battery charger.
Is it possible to charge these AGM batteries in 5-6 hours ?
What is the current and voltage required from battery charger in the inverter to charge the AGM batteries in 5 hours ?
Is it safe to charge the battery in 5-6 hours ? If not, what is the recommended charging time ?
Any special precautions to be taken with this kind of battery charger ?
