I have a 12V/3A dry battery. Can I charge it from a vehcile's 12V/8A battery. if yes how can I? I mean would I be connecting simple terminal to terminal? Should I take care of the 8amperes charging a 3ampere battery. kndly tell me how to charge. Thanks
Then tahmid the Higher current rating means high input power right so why can't it be charged
Or is charging independent of power input and only Voltage of the source
It depends on the charging voltage, provided the voltage doesn't drop under load. If it does, then charging won't happen.
