Channel Capacity in AWGN
gama
awgn channel capacity
in AWGN, we have channel capacity equation:
C = (½)log(1+SNR),
but if we use QAM16,
then the SNR means Eb/No or Es/No or Eav/No?
and even more if we are in Linear-filtering channel,
e.g, h(t)=0.8δ(t)-0.48δ(t-T)+0.36δ(t-2T),
then how we change the C equation or not?
thx.
gama
Aasem_sadek
Junior Member level 3
Egypt,Cairo
channel capacity qpsk
i guess the channel capacity = C=B log(1+S/N) not 1/2 log(1+s/n)
where S=Eb*Rb ;Rb is the bit rate
N=No*B ;where No is the noise power spectral density & B is the band width of channel
so i guess if you used the Es u shall use the Rs which = Rb/k ;where k=log (base2) M where K is the number of bits per symbol
& Es then is equal to Eb *Log(base 2) M which will get you back to Eb*Rb
note that this is valid for grey coding only ie: 1 bit error only allowed in the symbol
changfa
Full Member level 1
channel capacity awgn
The capacity C=B log(1+S/N) is measured in [bits/sec] while C=1/2 log(1+s/n) is in [bits/sec/Hz]. No difference.
Concerning the multipath situation, the capacity does change for sure. But, for your 16QAM, I do not have any idea. In general, however, you can transform the original channel to parallel channel (for example, OFDM technique) and get the capacity of this parallel channel as sum of individual channels.
Following reference might be helpful:
Digital Communication
by Edward A. Lee, David G. Messerschmitt
(I am sure it answers your first quesiton)
amihomo
Full Member level 5
Full Member level 5
PERSIAN Gulf
awgn equation
No Comment!
In an M-ary system :
Es/N0 (dB)=Eb/N0(dB) +log2(k) ,where k=code rate×log2(M)
(when coding is not used ,code rate is equal to 1)
Es/N0(dB)=10log10(Tsymbol/Tsampling) + SNR(dB)
and finally : C=B log(1+SNR)
It's that simple!
:D:D:D
changfa
Full Member level 1
channel capacity vs snr
amihomo said:
No Comment!
It's that simple!
:D:D:D
Sorry, but you ignore the informational meaning of C=B log(s+SNR).
Take Tsymbol=Tsampling and no channel coding for example, your equation goes unbounded when EbNo goes to infinity. This is not true since we know for example QPSK the capacity is limited to 2bits/sec/Hz no matter how large EbN0 (SNR) is.
    V
ahmedseu
Full Member level 3
Full Member level 3
Bahrain
capacity awgn channel
I think this thesis is one of the best in this field.
Regards
Reactions: Xavipersonal
    Xavipersonal
    V
amihomo
Full Member level 5
Full Member level 5
PERSIAN Gulf
capacity of awgn
changfa said:
amihomo said:
No Comment!
1) Es/N0 (dB)=Eb/N0(dB) +log2(k) ,where k=code rate×log2(M)
2) Es/N0(dB)=10log10(Tsymbol/Tsampling) + SNR(dB) , for complex input signals
3) and finally : C=B log(1+SNR)
It's that simple!
:D:D:D
Obviously there is no doubt that equation (1) and (3) are correct , to prove equation (2) :
Es/N0(dB)=10log10(S×Tsymbol/(N/Bn))
=10log10( (Tsymbol×Fs).(S/N) )
=10log10(Tsymbol/Tsampling) + 10log10(S/N )
where :
S=input signal power ,(Watts)
N=noise power ,(Watts)
Bn=noise Bandwidth ,(Hz)
Fs=sampling frequency ,(Hz)
(note that: Bn=Fs=1/Tsampling)
what you said about Eb/N0->∞ also holds if we let SNR->∞ in eq. (3) . and this not related to eq. (1) and (2)
changfa
Full Member level 1
channel capacity snr
amihomo said:
changfa said:
amihomo said:
No Comment!
It's that simple!
:D:D:D
where :
The problem is your logic. In your first post, it seems that you want prove (3) by (1) and (2), and this procedure does not hold for sure. For your second post, you want use (1) and (3) to prove (2), which itself has nothing to do with (3) at all.
The bottomline is: the famous C=B log(1+P/NB) bits/sec is defined for Gaussian channel and this value C is an intrinsic property of the channel. When we talk about a specific modulation scheme, we have to calculate its capacity curve (the above reference by some friend might help), which is definitely below the famous C~SNR curve.
    V
amihomo
Full Member level 5
Full Member level 5
PERSIAN Gulf
capacity awgn
Hi Changfa,
I didn't mean to prove eq (3) by (1) and (2), i meant to show how Eb/N0 and Es/N0 are related to the SNR in eq (3).
it is evident that C is an intrinsic property of the channel.As you know, by definition, channel capacity (C) is the maximum data rate at which reliable transmission of information over the channel is possible.And according to shannon's limit it is an upper bound for the reliable data rate we can achieve in any modulation scheme, i.e. , At rates R<C reliable transmission of information over the channel is possible .
regards
    V
spweda
Full Member level 3
Full Member level 3
capacity snr
The channel capacity is independent to the modulation format. If 16 QAM is used, it is more efficient than QPSK and more close to the channel capacity.
    V
