[SOLVED] Changing voltage for SMPS By DAC without neg supply for OPAMP
Paul GRIM
Junior Member level 1
Hi all,
I am designing a programmable inverting smps.
the output of the smps will vary between o to -10V.
i chose this circuit (two OPAMP and DAC and Vref for varying my output)
but if i use this circuit, it is necessary to have negative supply for the second OPAMP.
Is it possible to return this programmable circuit without a negative supply ?
Thank you
Paul
I believe you can design a circuit that uses out_n to supply the OP(s). ADJ don't need to swing below this level.
Hi FvM,
Thank you for your answer.
but i have a remark, if i supply the opamp by the output voltage i inject many noise to my OPAMP.
2) the output voltage vary = supply OPAMP very !! (and the offset of OPAMP change !!)
3) is it possible to use an other solution for driving this inverter without negative supply ?
Thank's
Paul
This trick can smooth the supply to your opamp. Install a resistor and extra smoothing capacitor.
2) the output voltage vary = supply OPAMP very !! (and the offset of OPAMP change !!)[/QUOTE]
If you want an unchanging supply voltage to the op amp, then a zener diode will do the job.
hi brad,
thank you for your answer
the output voltage vary = supply OPAMP vary !! (and the offset of OPAMP change !!)
Actually i havn't probleme in simulation, but in practical case i fear to have a bad surprise :thinker:
Paul
