shom_show
Member level 1
Myself Sumanta Kumar Show, Research Scholar in the Dept. of Electrical And Electronics Engg. of NITK Surathkal. I am using voltage sensor (LV25-P) and current sensor (LA 55-P). The voltage sensor is having a conversion ratio of (2500:1000) and for current sensor it is (1:1000). But in actual circuit we need a conversion ratio of (1:1) for both the sensors.
Please suggest the external circuit which can be added with the Sensor ckts for achieving the desired conversion ratios. I will be waiting for your response.
Thanks in advance.
Thanks in advance.
