Changes Made to Design to Remove False Path
spartanthewarrior
Full Member level 2
Full Member level 2
Hi All,
Can any body tell what all the changes I can made in my Design or RTL to
remove False Path from my design.
Regards
You cant do anything in RTL to remove false paths. They will be there. You can only declare them as false paths during synthesis.
kr,
Avi
a false path is use to tell STA tools not to analyze this path.
this path is your design's feature, such as reset path, ATPGEN path.
these path can not be removed from your design, because it is useful to your design. you must keep them.
If you find some false path is not useful, maybe you can remove them.
