RM2488
- Joined
- Apr 14, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,330
Hey all
New member here, first post. Please excuse if it is in the wrong section.
Here's what I'm currently working on: an H-Bridge implementation to drive a 56V17A DC Series motor.
Now, I have a TON of TIP142T/147T Darlington pairs as well as IRFP250N Mosfets. The voltage and current rating can be somewhat ignored since the motor will be undervolted. I'd prefer to use these (High side switching is not a problem for me here) since I just have them lying around.
Now to my main concern- if my calculations are correct, since the voltage drop in the BJTs will be max 3V (high+low), the max power dissipated can only be V x I ie 3 x 17 = 51.
I am somewhat new to mosfets, but assuming I fudge the heat sinking and the the mosfets are running hot, the max Rds(on) will be 3 ohms @175 degrees. That's 6 ohms in series with the motor. Assuming I am able to push the required amount of current through it (my calculations indicate otherwise), the power dissipation will be I^2 x R ie 17^2 x 6= 289 x 6 = 1734 W.
The Rds will be a minimum of 1 ohm at room temp, so that's 289 x 2 = 578 W!
This leads me to believe that the MOSFETs will be less efficient than the Darlingtons. I do this as a hobby, and I am sure I have overlooked things, but is my estimation correct? I intend to parallel the Darlingtons to get the current I want.
