Center tapping in ADS
Sadegh.j
Advanced Member level 3
Hi.
How can you get the middle node of an inductor in ADS? I want to use center tapping.
u can use the center tapped tranformer and ignore the other primary winding
what exactly u want to do with it ?
khouly
you can choose a 1:1 balun and connect two node together the you get an idea inductor with center tap
I read in a paper that using a "2-to-1" inductor tap will improve the Q of the varactor by a factor of 4. I just want to test it.
