nofre
- Joined
- Feb 2, 2007
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- ibov2010@yahoo.com
- Activity points
- 1,460
lcd_lib_4bit.c
i write an example to display on my LCD 16x2, use 4bits mode, only PortD
use the lib for LCD :
#include <stddef.h>
#define LCD_RS PIN_D5
#define LCD_RW PIN_D4
#define LCD_EN PIN_D13
#define LCD_D4 PIN_D1
#define LCD_D5 PIN_D2
#define LCD_D6 PIN_D3
#define LCD_D7 PIN_D12
// misc display defines-
#define Line_1 0x80
#define Line_2 0xC0
#define Clear_Scr 0x01
// prototype statements
#separate void LCD_Init ( void );// ham khoi tao LCD
#separate void LCD_SetPosition ( unsigned int cX );
#separate void LCD_PutChar ( unsigned int cX );
#separate void LCD_PutCmd ( unsigned int cX) ;
#separate void LCD_PulseEnable ( void );
#separate void LCD_SetData ( unsigned int cX );
#use standard_io (C)
#use standard_io (D)
//khoi tao LCD**********************************************
# void LCD_Init ( void )
LCD_SetData ( 0x00 );
output_low ( LCD_RW );
delay_ms(50); /* wait enough time after Vdd rise >> 15ms */
output_low ( LCD_RS );
LCD_SetData ( 0x03 ); /* init with specific nibbles to start 4-bit mode */
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_SetData ( 0x02 ); /* set 4-bit interface */
LCD_PulseEnable(); /* send dual nibbles hereafter, MSN first */
LCD_PutCmd ( 0x2C ); /* function set (all lines, 5x7 characters) */
LCD_PutCmd ( 0x0C ); /* display ON, cursor off, no blink */
LCD_PutCmd ( 0x06 ); /* entry mode set, increment & scroll left */
LCD_PutCmd ( 0x01 ); /* clear display */
# void LCD_SetPosition ( unsigned int cX )
/* this subroutine works specifically for 4-bit Port A */
LCD_SetData ( swap ( cX ) | 0x08 );
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) );
LCD_PulseEnable();
# void LCD_PutChar ( unsigned int cX )
output_high ( LCD_RS );
LCD_PutCmd( cX );
# void LCD_PutCmd ( unsigned int cX )
LCD_SetData ( swap ( cX ) ); /* send high nibble */
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) ); /* send low nibble */
LCD_PulseEnable();
# void LCD_PulseEnable ( void )
output_high ( LCD_EN );
delay_us ( 3 ); // was 10
output_low ( LCD_EN );
delay_ms ( 3 ); // was 5
# void LCD_SetData ( unsigned int cX )
output_bit ( LCD_D4, cX & 0x01 );
output_bit ( LCD_D5, cX & 0x02 );
output_bit ( LCD_D6, cX & 0x04 );
output_bit ( LCD_D7, cX & 0x08 );
And then the main:
#include "C:\CCSC\main.h"
#include "C:\CCSC\lcd_lib_4bit.c"
void main()
char V2[]="I Bet On Victory";
CHAR CONST SS[9]="QICKER!";
int8 i;
LCD_init();
LCD_PutCmd(0x01);
LCD_PutCmd(line_1);
LCD_PutChar(SS)
while (1) {
LCD_PutCmd(line_2);
for(i=0;i<16;i++)
LCD_PutChar(V2);
delay_ms(100);
i use PCWHD 4.057 , and nothing happen on my LCD !![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
is there any big mistake ? i'm too new at CCSC&dspic also , plz help
#include <stddef.h>
#define Line_1 0x80
#define Line_2 0xC0
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PutCmd( cX );
LCD_PulseEnable();
LCD_PulseEnable();
And then the main:
void main()
int8 i;
LCD_init();
LCD_PutCmd(0x01);
LCD_PutCmd(line_1);
LCD_PutChar(SS)
while (1) {
LCD_PutCmd(line_2);
for(i=0;i<16;i++)
LCD_PutChar(V2);
delay_ms(100);
