I am using launchpad board "TMS320F28069M ". While loading the program to the TMS320F28069M microcontroller there is no issue, but while debugging the program, it shows rise in temperature. We checked for the temperature of the controller and it shows around 40 - 45 degree Celsius.
The same phenomenon is observed in our self made circuit board(using TMS320F28069M microcontroller only).We tried giving power supply via USB and then started debugging in our self made circuit board,but same rise in temperature occurred and also We tried giving power supply via power adapter but no changes occur .
In our self made board, the peripherals are:-
All SPI protocol peripherals :
• GPIO-EXPANDER "(MCP23S17)
• Ethernet chip(ENC28J60)
• can-fd (CANFD controller-MCP2518FD, transceiver ATA6561)
All i2c protocol peripheral:
• EEPROM(at24c32)
• RTC(DS3231)
• DAC(DAC7678)
Serial communication
• RS232
The DAC output is connected with signal conditioning circuits and the dac has 8 channels. We have used ADP5070 as negative power supply for supplying signal conditioning circuits.
GPIO-EXPANDER "(MCP23S17)and the GPIO-EXPANDER have 16 in/out pins.16 in/out pins are connected with 16 opto-couplers and the each opto-couplers connected with one relay.Same spi pin connected with Ethernet chip(ENC28J60) and Ethernet chip(ENC28J60) connected with RJ45.
The GPIO-EXPANDER , Ethernet chip SPI pin and CAN-FD SPI pin is different .
Whenever I am uploading codes to program any of the peripherals, the controller(TMS320F28069M) gets hot and it's temperature reaches around 40-45 deg Celsius.
12V is Input for both 3v and 5v External power supply circuit .We tried giving power supply via USB and also We tried giving power supply via adapter in both cases the controller is getting hot. (hot is not like burning sensation but quite hotter) . Kindly give your insights to solve this heating issue.
