CCS C and MPLAB accomodation
season2
Newbie level 3
Newbie level 3
turkey
Hi Friends;
I have got us-burn (brenner 8) and hand book CCS C. Also I have a software cd including,
us-burn V1-10A.2 (zip files directory)
us-burn V1-10A.5 (zip files directory)
us-burn V1-11A.2 (zip files directory)
us-burn V1-11A.5 (zip files directory)
and MPLAB_IDE_V8_66.exe Directory (My pc has Windows 7)
After installation, I downloaded CCS C plugin.exe then running the mplab debugger, all steps completed but receving a message While hex file being created (under "make" command). "PCM: Can not find dll" (The DLL file for the compiler can not be found. This occur when the all compilers are not downloaded or the wrong packace was downloaded).
Please advise, which one the message means; "mplab or CCS C". I am not sure that I installed MPLAB correctly or should I download CCS C completely.
Regards.
I ralized that HI-TECH Compiler is embedded inside CD and I have tried it as "active tool suite" and it is OK. Build is successful.
it here is a warning or error message like "build failed" your entries wrong but if you receive a message like "need dll, crg file" means CCS C is not properly installed.
