evilheart
Member level 3
i am currently on a design using Texas instruments CC3000 wifi module and i am facing problem with the matching circuit , using antenna.
too bad i am not experienced RF designer so designing my own matching circuit can be a bit risky and time consuming,
there's a matching circuit provided in the datasheet with the ACX AT8010-E2R9HAA antenna , which seems it's not on the market anymore so i used the johnson 2500AT04M0400 which is equivalent (ACX and johnson companies are partners) ,
but i have no idea why those values are used or why we are using matching circuit at the first place while the (antenna - track - CC3000) are already matched.
They say in the data sheet that the values given are for the EM board , but i don't know what that exactly means , does that just mean i need another values if i changed the antenna?
or that every circuit is unique and that these values depends other factors that i don't know yet?
if i need to design my own matching circuit , can any one please recommend a good guide/tutorial/tool for that ??
regards
regards
