prajesh
Newbie level 1
hi, i am working on car control using speech recognition but i have problem with extract at 214 line.
please help me to solve this problem.
here is my code.
function test_project
clc;
close all;
clear all;
a=0;
data1=[0 0 0 0];data2=[0 0 0 0];data3=[0 0 0 0];data4=[0 0 0 0];data=[0 0 0 0];val1=[0 0 0 0];
for i=1:100
for i=1:10
fs=22050;
y1=wavrecord(fs,fs,1);
wavwrite(y1,fs,16,'C:\MATLAB7\work\user.wav');
a=wavread('C:\MATLAB7\work\user.wav');
wavplay(a,fs);
n=input('Enter 0');
if(n==0)
break;
else
disp('Record your voice again');
end
end
filename = 'C:\MATLAB7\work\New Folder11L.wav' % Calculate the codebook vector.
cep = learn('C:\MATLAB7\work\New Folder11L.wav');
codebook = vqlbg(cep, 8);
result(1) = identify(filename, codebook);
cep = learn('O.wav');
result(2) = identify(filename, codebook);
cep = learn('U.wav');
result(3) = identify(filename, codebook);
cep = learn('V.wav');
result(4) = identify(filename, codebook);
% Test a file.
if ( ( result(1) < result(2) ) & ( result(1) < result(3) ) & ( result(1) < result(4) ) )
'L'
end
if ( ( result(2) < result(1) ) & ( result(2) < result(3) ) & ( result(2) < result(4) ) )
'O'
end
if ( ( result(3) < result(2) ) & ( result(3) < result(1) ) & ( result(3) < result(4) ) )
'U'
end
if ( ( result(4) < result(2) ) & ( result(4) < result(1) ) & ( result(4) < result(3) ) )
'V'
end
% For Checking the Output and Data given to the parallel port
Select=input('Enter 0 for TRUE Output ');
if(Select==0)
if(ans=='L')
data=[~val1,1) val1,2) val1,3) val1,4)];
end
if(ans=='O')
data=[val1,1) ~val1,2) val1,3) val1,4)];
end
if(ans=='U')
data=[val1,1) val1,2) ~val1,3) val1,4)];
end
if(ans=='V')
data=[val1,1) val1,2) val1,3) ~val1,4)];
end
dio = digitalio('parallel','TPI1');
addline(dio,0:3,'out');
putvalue(dio.Line(1:4),data);
val1 = getvalue(dio)
end
Close=input('Enter 5 for Exit');
if(Close==5)
break;
end
end
% ---------- MARS MARS MARS MARS MARS ----------
%%%%% IDENTIFYING THE FILE %%%%%
function dist = identify(file, codebook)
[filedata, fs] = wavread('C:\MATLAB7\work\New Folder\user.wav');
truncated = extract(filedata);
cep = mfcc(truncated);
d = disteu(cep', codebook);
dist = sum(min(d,[],2)) / size(d,1);
%%%%% LINDO,BUZO,GOLD VECTOR QUANTIZATION %%%%%
function centroid = vqlbg(cepstrum, M)
% FEATURE MATCHING
% STEP 1 - INITIALIZATION
centroid = medel(cepstrum);
centroid = centroid';
cepstrum = cepstrum';
epsilon = 0.01;
%M = 8; % The size of the codebook
m=1;
while (m<M)
% STEP 2 --- DIVISION
temp_cent = centroid;
j = 1;
for i=1:m
centroid,j) = temp_cent, i) * (1 + epsilon);
j = j + 1;
centroid,j) = temp_cent, i) * (1 - epsilon);
j = j + 1;
end
m = 2*m;
test_var = 0;
D_prim = 99999999; % Init D_prim to a sufficient large value.
while (test_var == 0)
% STEP 3 --- CLUSTERING
dist = disteu(cepstrum, centroid);
[magic, ind] = min(dist, [], 2);
% STEP 4 --- UPDATE
D = sum(sum(dist));
if ( ( (D_prim - D) / D) < epsilon)
test_var = 1;
else
D_prim = D;
end
end
end
%%%%% FINDING EUCILIDIAN DISTANCE %%%%%
function d = disteu(x, y)
[M, N] = size(x);
[M2, P] = size;
if (M ~= M2)
error('Matrix dimensions do not match.')
end
d = zeros(N, P)
if (N < P)
copies = zeros(1,P);
for n= 1:N
d(n, = sum((x, n+copies) - y) .^2, 1);
end
else
copies = zeros(1,N);
for p = 1
d,p) = sum((x - y, p+copies)) .^2, 1)';
end
end
d = d.^0.5;
%%%%% LEARNING AND MFCC %%%%%
function cep = learn(file)
[filedata, fs] = wavread('C:\MATLAB7\work\user.wav');
%%%%% EXTRACTING FEATURES %%%%%
function sampledata = extract(xin, length)
length=16;
mean = 0;
for i = 1:1000
mean = mean + (abs(xin(i)) / 100);
end
threshold = mean * 2 ;
for first_index = 1:size(xin)
if (abs(xin(first_index)) > threshold)
break;
end
end
for end_index = 1:size(xin)
temp = size(xin) - end_index;
if (abs(xin(temp(1))) > threshold)
break;
end
end
sampledata = xin(first_indexsize(xin) - end_index));
%%%%% MEDEL %%%%%
function m = medel(v);
[nr_of_rows, nr_of_columns] = size(v);
for i=1:nr_of_columns
m(i) = sum(v(1:nr_of_rows, i)) / nr_of_rows;
end
%%%%% DETERMINING MEL-SPACED FREQUENCY BANK %%%%%
function m = melfb(p,n, fs)
p=20; % number of filters in filterbank
n=256; % length of fft
fs=22050;
f0 = 700 / fs;
fn2 = floor(n/2);
lr = log(1 + 0.5/f0) / (p+1);
% convert to fft bin numbers with 0 for DC term
bl = n * (f0 * (exp([0 1 p p+1] * lr) - 1));
b1 = floor(bl(1)) + 1;
b2 = ceil(bl(2));
b3 = floor(bl(3));
b4 = min(fn2, ceil(bl(4))) - 1;
pf = log(1 + (b1:b4)/n/f0) / lr;
fp = floor(pf);
pm = pf - fp;
r = [fp(b2:b4) 1+fp(1:b3)];
c = [b2:b4 1:b3] + 1;
v = 2 * [1-pm(b2:b4) pm(1:b3)];
m = sparse(r, c, v, p, 1+fn2);
%%%%% MEL-CEPSTRUM %%%%%
function cepstrum = mfcc(x)
% FRAME BLOCKING
j=1;
i=1;
[s1, s2] = size(x);
%x(1: 256)
while ( (j+256) <= s1)
for( k=1 : 256)
x_new(i,k) = x(k+j-1);
end
i = i+1;
j = j + 256;
end
% WINDOWING
j=1;
i=1;
[s1, s2] = size(x);
w = hamming(256);
for( k=1 : 256)
x_new(i,k)=x_new(i,k) * w(k);
end
i = i + 1;
j = j + 256;
end
% FAST FOURIER TRANSFORM
j=1;
i=1;
x_new_freq(i,1:256) = fft(x_new(i,1:256));
i = i + 1;
j = j + 256;
end
% MEL FREQUENCY WRAPPING
nr_of_filters = 20;
m = melfb(nr_of_filters,256, 11000);
n2 =1+floor(256/2);
i=1;
j=1;
for (k=1:nr_of_filters)
z_prim = (m * (abs(x_new_freq(i,1:n2)).^2)'); %'
z(i,k) = z_prim(k);
end
j = j + 256;
i = i + 1;
end
i=1;
j=1;
cepstrum_prim = dct(z(i,1:nr_of_filters));
cepstrum(i,k) = cepstrum_prim(k);
end
j = j + 256;
i = i + 1;
end
resolution = i-1;
if u have another code for matlab then also send it to me.
here is my code.
clc;
close all;
clear all;
a=0;
for i=1:100
for i=1:10
fs=22050;
wavplay(a,fs);
n=input('Enter 0');
if(n==0)
break;
else
end
end
% Test a file.
'L'
end
'O'
end
'U'
end
'V'
end
if(Select==0)
if(ans=='L')
end
if(ans=='O')
end
if(ans=='U')
end
if(ans=='V')
end
end
if(Close==5)
break;
end
end
% FEATURE MATCHING
epsilon = 0.01;
m=1;
while (m<M)
j = 1;
for i=1:m
j = j + 1;
j = j + 1;
end
m = 2*m;
test_var = 0;
% STEP 4 --- UPDATE
D = sum(sum(dist));
test_var = 1;
else
D_prim = D;
end
end
end
[M, N] = size(x);
[M2, P] = size;
if (M ~= M2)
end
d = zeros(N, P)
if (N < P)
for n= 1:N
end
else
for p = 1
end
end
d = d.^0.5;
length=16;
mean = 0;
for i = 1:1000
end
break;
end
end
break;
end
end
%%%%% MEDEL %%%%%
end
fs=22050;
f0 = 700 / fs;
fn2 = floor(n/2);
b2 = ceil(bl(2));
b3 = floor(bl(3));
fp = floor(pf);
pm = pf - fp;
% FRAME BLOCKING
j=1;
i=1;
[s1, s2] = size(x);
%x(1: 256)
for( k=1 : 256)
end
i = i+1;
j = j + 256;
end
% WINDOWING
j=1;
i=1;
[s1, s2] = size(x);
w = hamming(256);
for( k=1 : 256)
end
i = i + 1;
j = j + 256;
end
j=1;
i=1;
i = i + 1;
j = j + 256;
end
nr_of_filters = 20;
n2 =1+floor(256/2);
i=1;
j=1;
z(i,k) = z_prim(k);
end
j = j + 256;
i = i + 1;
end
i=1;
j=1;
end
j = j + 256;
i = i + 1;
end
resolution = i-1;
