Zerox100
Full Member level 6
I have faced a very strange thing.
I am designing a FPGA board. I had +5v and +3.3 v power on board. i created +3.3v from +5 by two serial diode. When i placed two smd diode i saw the 3.3v voltage is actually about 2v. I checked the circuit. I saw every diode falls about 1.4v. I supposed that they are double diodes (two serial diodes in one package). then i removed one of them and replace the one of diodes by a zero R. the power started to works and every thing was OK.
After finalizing the board and finishing coding of FPGA, I checked the diode again. They were not diode!!!!! It was a mistake. they were polar capacitors (3.3uf). But they were working like diodes without any problem for a long time!!!!!
What do you think??? Are they capacitors made by reverse diodes???? Is it possible????!!!
