Robertt
Junior Member level 3
poly resistor layout
Should I put capacitors and resistor in Nwell?
Added after 11 minutes:
one more question:
I use poly to draw the resistor layout, if it is not good useing the minimum ploy width as the resistor width.
Say, is the minumum poly width should be 0.6um. I draw the resistor with 0.6um width and then adjust the length to get the desired resistance value. Is that good?
I doubt it. My reason is that, in process, there will be variations, if we use the minimum width, the resistance value variation should be large because of the process variation. So we should choose lager width.
But I am not sure if I am correct or my worry is redundant. If I am correct, which width value we should choose for resistor layout? in the above example, 1.2um is a good choice?
one more question:
