Can you describe your questions in more detail? Not sure you want to know the mechanism of the crosstalk or something else. If you want to know something about the cosstalk in between coupled TLs caused by parasitic inductance and capacitance, I can give you a brief description.
Anytime, there is a step up/down source change, it will couple the noise to the adjacent lines via parasitic capacitance Cm and inductance Lm, since the noise coupled through Cm is in fact the displacement current, it can flow to either direction of the victim line, tbus the so-called Near and Far end crosstalk caused by Cm have the same polarity (+), while the induced current caused by Lm has an opposite direction to the original current(current flowing on the active net), near end and far end cross talk will have opposite polarity ( + for near end and - for far end). As a result, the overall near end crosstak will be:
I_near=I(Lm) + I(Cm)
I_far= -I(Lm) + I(Cm)
active net _ --------------------------
_/
passive net ---------------------------
Near end Far end
Hope this helps.
Regards,
