cantileve beam design of series switch using Covento
pratik bheley
india
facing problem in MEMmech simulation please help
hello sir,
i am facing problem MEMmech simulation of coventor as (help mannual for beam design is for shunt switch) & iam designing series switch
problem-surface BC (in fix -fix beam type) their are two anchor 1 & 2 (as mentioned in MASTERHELP HELP MANNUAL)
but in our case their is only one anchor,so in surface BCS environment in set1 fix type Fix All there is patch1 i have mentioed only one anchor1& patch2 =none,SET 2 FIX TYPE-LOAD PATCH ->patch 1-top beam . but still it failed to simulated
i have change combination to and1 to and/ or but still it couldn"t simulated please help
thank you
pratik
