[General] Cant access ATC1000 ethernet to serial conveter IP
YGSH
Newbie level 5
Hello Fiends,
I am trying to access atc1000 ethernet to serial converter using ip 192.168.2.1(As given in act1000 datasheet) but not getting any response. Changes in PC setting has made to assign address in the 192.168.2.2 to 192.168.2.254 range with a subnet mask of 255.255.255.0.
I have used this unit, almost 6 month ago and was working fine. But may be i changed his ip, later on and forget it. ::) ::) ::) But now i am unable to access it. :smiley-confuse:
So does any one knows, How to do it????
See ACT1000:
[image found at: lghttp .14131 .nexcesscdn .net /806B12 /gridconnect /media /catalog /product /cache /1 /image /9df78eab33 525d08d6e5fb8 d27136e95 /G/C/GC -ATC-1000_1 .jpg]
what is the status of LEDs(Link/ACT/PWR) when you switch on ?
Are you able to enter into the 192.168.2.1 configuration pages ?
Link LED is Blinking randomly...... ACT LED if OFF ..... and PWR i.e. Power Led is ON permanantly....
When i am trying to access 192.168.2.1, the browser time outs
is the ethernet interface of the PC working?
first check it by connecting to any other device than ACT1000.
test with a good ethernet cable between PC and other device.
Hurray!!!! Got the info about how to factory reset all setting of ATC1000(which will reset it's IP also):fight::fight:
Now Working all properly and accessing the 192.168.2.1 is done........ Thnx
First opened the unit atc1000, there is switch near power socket, pressed it on power on and DONE....:)
Now entire universe can be accessed :-D
