Dec 2, 2008 #1 S sevid Member level 2 Joined May 20, 2006 Messages 53 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,711 saif file hi,everyone in my testbench, i want to create a SAIF(Switching Activity Interchange Format) file directly with the system functions list as following: $set_gate_level_monitoring("rtl_on"); ... ... but the vcs report a syntax error of the function. i wonder that if vcs has the function and there is somethine wrong with using it. thanks in advance. sevid
Dec 2, 2008 #2 R rjainv Full Member level 2 Joined Feb 18, 2007 Messages 138 Helped 18 Reputation 36 Reaction score 4 Trophy points 1,298 Location Bangalore, India Activity points 2,066 vcs saif You can use UCLI prompt to dump saif files directly. Make sure you use the latest version of VCS ( 2006.06-SP2-7 or later). Compile with -debug or -debug_all option, When running, add -ucli option to commandline, this will give you ucli prompt. "power -help" will give you info on saif dumping.
Dec 5, 2008 #3 S sevid Member level 2 Joined May 20, 2006 Messages 53 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,711 saif file format thanks to rjainv but i cannt generate a saif file with ucli prompt. and i cannt get it from ucli user guide. and the "power -help" command is not available in ucli prompt. what can i do then thanks in advance. sevid
Dec 5, 2008 #4 R rjainv Full Member level 2 Joined Feb 18, 2007 Messages 138 Helped 18 Reputation 36 Reaction score 4 Trophy points 1,298 Location Bangalore, India Activity points 2,066 saif generate Are you sure you are running with latest version of VCS ? I have seen that 2006.06-13 doesn't support it, while 2006.07-SP2-7 does. I am not sure in which version they introduced "power" command to ucli prompt.
Dec 6, 2008 #5 S sevid Member level 2 Joined May 20, 2006 Messages 53 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,711 saif vcs thanks to rjainv it's my mistake. my vcs is not the latest, but only a 05 version. i use "vcd2saif" command instead. thank u very much. sevid
