scdoro
Member level 5
Hi all,
The following is the question on finding the behavior of impulse response with some information provided.
A discrete-time LTI system has frequency response H (ω ) and corresponding
impulse response h[n]. Given that
a. The system is causal.
b. H(ω ) =H∗ (ω )
c. The DTFT of the sequence h[n+1] is real.
Show that the impulse response of the system is of finite duration.
If, in addition to the above, the frequency response has the following properties
d. H (π ) = 0
e. 1 ( ) 2
H d π
π
ω ω
π −
Is there enough information to identify the system uniquely? If so, determine the
impulse response h[n]. If not, specify as much as you can regarding h[n].
thanks
regards
b. H(ω ) =H∗ (ω )
d. H (π ) = 0
e. 1 ( ) 2
H d π
π
ω ω
π −
thanks
regards
