Can P&R the post-map simulation model?
chifalcon
Newbie level 6
Spain
I need to modify the netlist generated from "Generate Post-map simulation model"(or by netgen).
After the netlist modifcation, can I continue the work of place&route based on the modified simulation model netlist? Or this post-map simulation model is just for the simulation?
Thanks!
Eric
You can continue with the P&R. only if you change the source file for the P&R which is different from the simulation model, you will get the issue of re-synthesis. Otherwise this will work fine.
