Can I use MOS in the off state to obtain large resistance?
elbadry
Full Member level 6
Egypt
Dear all,
Can I use a MOS in the off state to obtain an extremely large resistance ( in the order of 100 G ohms ).
Or is there something incorrect about doing so?
Regards,
elbadry
tamerakshar
Full Member level 1
Re: MOS in the off state
hey,
No you can't ,the mos will fail.
TeE ThE EdE
darkk
Member level 3
why do u need that huge resistance? you need to tell more.
gigle
Junior Member level 1
Considering junction leakage current, I would say "it is not practical"
elbadry
Full Member level 6
Egypt
I need it to form a LPF with a very low cutoff. I use this filter to reduce noise
I feel that, from a physical point of view, there is nothing wrong with using the MOS in off state.
The resistor would be places in a path in which the current is already zero ( series with a MOS gate)
gevy
Full Member level 6
Russia
You can to use switched capacitor as very high resistor,
which has equivalent resistance R = 1 / ( C * F ), where F - frequency of switching.
kwkam
Full Member level 5
Somewhere on earth
You can try Poly without salex / P+ / N+ as resistor. The order of resistance in 10G Ohm
