Can I use JTAG ICE INSTEAD OF programmer?
leilarazavi2000
Member level 2
how can i use jtagice isp
HI
I want to build JTAG ICE in system debuger
I read that jtag ice can reprogram flash ( write BREAK ins. to avr for stop avr at break point )
Can I use JTAG ICE INSTEAD OF STK200 programmer to full programing avr ?
7rots51
jtag ice 16
Yes,with JTAG you can do software debugging and programming of micro in both JTAG and in ISP mode.
In JTAG mode you can program FLASH and EEPROM and Fuse bits ,you can do this also in ISP mode of JTAG ICE.
leilarazavi2000
Member level 2
jtagice isp mode
but jtag connector is different to ISP connector !
dipal_z
Full Member level 5
India
Thats correct because ISP uses SPI interface for programming and JTAG uses Test Port signals as defined in JTAG specs. Thats why programming algorithm and signals used in both the cases are also different. Basically programming is achieved in two totally different ways.
7rots51
In AVR studio in tools menu connect to JTAG ICE.
In the appeared windows you can select JTAG as interface and program micro with JTAG port (you should use JTAG connector in hardware)
I the appeared window you can select ISP as interface and program micro with ISP port(you should use ISP connector in hardware0
moatazfaize
i did ,t found JTAG ICE plan and avr ..
can u help me
Mindaugasu
Member level 3
I have successfully built JTAG ICE clone and it is working for me. yes you can program AVRs with this JTAG adapter, but only those who have JTAG port in it.
Building AVR Jtag clone
Testing AVR Jtag in action
